How do I fix this?
Old Feb 27, 2005 | 11:41 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
How do I fix this?
The plastic accent panel (I dont know what it's called) that attaches to the bottom of the door on a 92' RS is coming off. It's on the passenger side of the car. The only thing holding it on there are the ends, the middle has popped out of the little track that I think it fits in, I've tried putting it back on, but whats the best way to go about it?
Thanks,
Max
Old Feb 27, 2005 | 06:58 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
What you need to do is take off your door panel and there are nuts inside the door that hold the metal bracket on for the ground effect. There are also rivets on the underside of the door. What I would do would be to just take it all off and put the metal bracket and the ground effect together if you can and put it up to the door as one unit. Hope that helps
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
