Hatch Lock-out
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
Hatch Lock-out
Hey all, i have an 87 camaro and i cant find the keys for the door locks, so i replaced the 2 door locks with no problem, but now im stuck. i cant get the interior panels off from the hatch area to access the hatch lock mechinism. what is the best way to pop that baby open?
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Do you have some pics? If I understand what your asking, you should just be able to unscrew the plastic panel from the back of the trunk. Then you would have full access to the hatch motor and lock. What is stuck, exactly?
Axle/Gears: 4.10
stuck just meaning i dont know wht to try next. problem is, that i cant get those panels off from the inside because i have the cover that hinges down in the back and i cant get that off, so i dont have access to the rear most trim pieces ill try to post a pic tommorow
Axle/Gears: 3.45, 3.27, 3.27
Pop out the hatch light. You should be able to remove the 10mm screw holding on the manual or solenoid hatch release. With that aside you'll see a square hole. Inside is the tab that you'll rotate CCW to pop the hatch.
Lon
Lon
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:00 PM
