Check out my new gauge pod
Old Mar 12, 2005 | 04:40 PM
onebinky's Avatar
Just finished it a few minutes ago. I'm undecided on a couple things, thought I'd get some input here. My initial idea was to create a backdrop behind the panel, and then use some bright LED's to light the whole area behind the gauges.
My dad just gave me the idea to use some colored laminate behind the gauges, which I also think would look awesome.
The panel itself is 1/4" acrylic extrusion. It's supposed to be 10x stronger than plexi, and not as rigid as lexan.
Let me know what you think
Attached Thumbnails Check out my new gauge pod-c-documents-settings-owner
Old Mar 12, 2005 | 04:44 PM
onebinky's Avatar
Oh, in the semi vacant section between the gauge halves there will be a few LED's. My turn signals, brights, check engine, and ALDL communication. I may add a few in the lower corners for WOT, and a few dummy lights for my gauges. They will all be mounted cleanly BEHIND the acrylic panel, so I can maintain the clean, finished look on the exterior.
All the gauges except the oil and water are VDO. The oil and water are mechanical auto gage. When I get some more $$$ I will upgrade to electronic VDO.
Old Mar 12, 2005 | 10:32 PM
TylerM's Avatar
awesome idea. one of the best most original ideas i have seen in a very long time. congrats. may even attemp a similar one myself
Old Mar 12, 2005 | 11:14 PM
Adrenaline's Avatar
Car: 92 Camaro RS
How long until you get it in the car with pics for us to see?
good job btw... looks good.
Old Mar 12, 2005 | 11:22 PM
onebinky's Avatar
Thanks guys
It all depends on the weather around here. Hopefully within a couple weeks I'll have it in.
I have a white face auto gage tach for sale if you know anyone interested. It's 3.5" IIRC. $35 plus shipping.
Old Mar 13, 2005 | 12:56 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Looks clean, can't wait to see it after it's installed.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
arod231
Aug 16, 2015 02:51 PM
89lsc
Aug 14, 2015 04:58 PM
