86 T/A spoiler is rubber?
Old Mar 17, 2005 | 09:05 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I just got an 86 Trans Am and the spoiler is all pitted and eaten away. I look closer and its made of rubber or something similar. I assume I have to replace it since I can't bondo or sand it. I'm considering trying spray on bedliner since thats what it looks like right now. Any tips for repairing it? Is it even stock? And can I fit my louvers on it?
Old Mar 17, 2005 | 09:06 AM
Car: 86 T/A
Engine: HSR 355
Here's the best pic I have of it.
Attached Thumbnails 86 T/A spoiler is rubber?-img_1517.jpg
Old Mar 17, 2005 | 11:12 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Yes, it's stock. When I got my car, the aerowing was also very faded and pitted. It looked pretty bad, so I took the thing off and repainted it. I didn't really do any sanding, because I wasn't sure if it would just make it worse. I found some spray paint at Lowes that was for rubber or plastic, so I got a few cans of that and a can of primer. I first used the primer and then applied a few coats of the gloss black paint. Now, it looks great, but the pits are still visible up close.
Old Mar 17, 2005 | 06:47 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
if you plan on keeping your car for a while and especially painting it, get the fiberglass one. IMHO its not worth the effort vs quality of results to fix the stock one even tho the fiberglass is expensive.
Old Mar 17, 2005 | 07:59 PM
Car: 86 T/A
Engine: HSR 355
I plan on keeping it but I'm not paying $300+ for a spoiler when I can fix this up for under $20 and some time.
Old Mar 19, 2005 | 04:06 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Part of the problem with those spoilers is that water wicks up the attachment points and causes the steel inside to rust. When the steel inside rusts, it causes the rubber to split. Repairing the outside only will not solve the problem. What I did was grind out the rubber around the steel, POR-15 it, then fill up the area around the steel with sealant. After all that was done, I fiberglassed over the sealant and the crack. It looked okay, but I never did paint mine because I decided to get a fiberglass replacement due to the original spoiler's weight disadvantage. I hated popping the latch button and having to bolt out of the car door to get to the hatch before the weight of the spoiler caused the hatch to shut by itself.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
Gordonr1973
Sep 29, 2015 11:59 AM
