Side window removal
Old Mar 23, 2005 | 03:47 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Side window removal
I'm deep into "restoring" my 92 camaro. I gutted the doors today getting ready for the body shop. I had a little trouble getting the windows out of the doors with all the rollers, brackets still attached to the window. I've not had much luck with the search function with this. I know this will be a pain to reinstall when the car is painted. My question is. Do I remove all the hardware from the windows then reinstall after it's in the door? Do I use rivets or bolts and nuts?
Old Apr 26, 2006 | 08:54 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I did a search and found this post.
What did you come up with? I have the same question now.
Did you have to remove the brackets?
Thanks.
Old Apr 26, 2006 | 11:18 AM
pondriver's Avatar
Engine: 350 HSR
Well, my car is just now getting painted so, I haven't done anything yet. I will more than likely drill out the rivets and reinstall with bolts and nuts with locktight.
Old Apr 26, 2006 | 11:23 AM
Scorpner's Avatar
Engine: V6, V8
I haven't done this yet but I was told you can get the rivets from the dealer and the rivet tool from Harbor freight. I found out about the tool on this board when looking at replacing the window motors. IIRC it's about $20 for the tool.
Also, I was told to punch out the centers of the rivets, but I don't think that will work with glass. (The center pin is a harder metal.) that's all I know so far...
Old Apr 26, 2006 | 01:50 PM
ajhagerman's Avatar
Yes you need to punch out the center of the rivet...its a rush to R&I a 3rd gen window. After you punch out the center you can drill the head off..use a sharp bit..heres a good tip..grab the back of the rivet with a rag, it will keep the rivet from spinning.
Have fun!
Drew
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
pfsteichen
Feb 9, 2016 06:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
