Not enough basecoat - how do I fix?
Old Mar 23, 2005 | 08:22 AM
kaupca's Avatar
Car: 92 Camaro RS
Recently painted a car with BC/CC and after moving it outside in the sun I noticed some places where there was not enough basecoat (primer kinda showed). Can I scuff this up with some 400(?) grit, respray the basecoat in that one area and then re clear coat? Should I reclear the whole panel? I need your ideas expertise on what to do. Thanks
Old Mar 23, 2005 | 08:26 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
when you say in some spots, were is it at? All over the car in different spaces, or on just a certain panel?
If it is all over the car in different spaces, then I suggest a total repaint. If it is just on the hood or maybe a door/fender, then you may be ok to do a spot job. Do you have any of the paint that you used left?
Old Mar 23, 2005 | 09:38 AM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
Also what type of color, like is it a solid, mettalic, or a candy??
Old Mar 23, 2005 | 11:41 AM
kaupca's Avatar
Car: 92 Camaro RS
The problem is near the bottom of one fender and on the adjacent door. I still have some of the paint the car was painted with, It is a sold black. What grit to scratch up the surface? Wet or dry? Thanks
Old Mar 23, 2005 | 12:30 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Great answer. Black is good!
Just wetsand with 400 both the door and fender. Then just respray with the black and then re-clear the panels. Shouldnt need to blend with black. May have to wetsand and buff later to get the textures to match.
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
