finish film instead of wet sanding
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
http://autobodystore.net/Merchant2/m...tegory_Code=M3
anyone ever try this process of finish film instead of wet sanding. i just ordered up the system with a new sander to try it on the z. i already wet sanded the car once and it needs another go and i didn't feel like rubbing again, i hear good stuff about this process for time savings and end results of being excellent.
jeff
jeff
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am saving that link and showing it to my friend who painted my car. Need to get the orange peel out and this may save time, like you mentioned.
Car: 82 Camaro Z28
Engine: Long Rod 383
Transmission: 350 with 3300 stall converter & 4.10 gears.
Yes!!!!! I've done this for a few years now..I wasn't quit sold
on it at first so I tried it on a few cabinet's that I flamed..
I use the 3M system,,, And all I can say is (Works Great)..
First !! Also tried it on a 64 buick Rivie GS with dual Quad set up,
From there on--- I use it on all vehicle's now...
Good luck...
Engine: 305 tpi LB9
i used the finish film today 1200 grit with an airvantage sander i also purchased at autobody depot. man is this thing a time saver and works great i wil never wet sand again...
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Lookin' Great as usual Jeff.
Actually my guys use this, then buzz the entire surface, that was dry sanded, wet, with a DA/3000g with an interface pad. Works good for an OEM type look. But for my money you can't beat that old fashioned had sanded finish.
I used to use a similar product about 15 years ago, but the clears just weren't up to snuff. The old DELGLO style clears used to ball up and leave little trails in the finish that had to be wetsanded in the end anyways.
2000, airvantage, autobody, film, finish, finishfilm, grit, massachusetts, sander, sanding, wet, youtube
