steering wheel problem
Old May 7, 2005 | 03:00 PM
808RS's Avatar
Car: 91 RS
Engine: 305TBI
i just installed my grant steering wheel on a 91 camaro but it feels like the wheel is on 2 tight should i sand down the plastic on the hub?
Old May 9, 2005 | 04:01 PM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
Re: steering wheel problem
After installation there is either a large gap or rubbing (interference) between the post cover and my steering column. How do I correct this?
In designing Grant kits, we allow for a 1/8" gap between the post cover and the steering column. Many older vehicles may have been modified, rebuilt or repaired and have had the steering columns removed from the vehicle. There is adjustment built into many of these columns. Loosen the bolts holding the column into position under dash and slide the housing up or down to the desired clearance and then retighten the bolts securely.
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
