Rear seat 3-point seat belt conversion?
Old May 15, 2005 | 01:03 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
My 86 IROC only has lap belts in the rear. With the kids in car seats this is not a problem, however when they move to booster seats I'll need a native three point seat belt in the rear for them to sit there (My 4 year old sits in the front seat). Do you know of any kits where I can convert my lap-only to three-point? Will seat belts from a 4th gen fit?
Thanks!
Old May 15, 2005 | 01:52 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You could probably get the hardware and mounting brackets out of an 89-92 thirdgen and weld the brackets in for the retractor above the rear wheelwell. You'll also need the rear interior plastics from an 89-92 to fit over the retractor.
I believe the fourthgen belts mount the same way. Not sure if the bracket itself is interchangeable, but at least the belts would be 'newer'.
Old May 15, 2005 | 02:47 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i just went to do this, the driver side will not fit correctly, the inner wheel well is different on 89+
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
AkDrifted
Aug 17, 2015 07:45 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
