how do i remove top door trim piece and the door panel?
Old May 21, 2005 | 11:36 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
how do i remove the top plastic panel near the window sill and the door panel so i can replace it and the triangle piece on the window? what type screws do a 87 camaro have on the triangle piece
Old May 22, 2005 | 12:14 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Take the arm rest assembly off, and the trim around the inside handle (if manual windows remove the window crank). Carefully, pull the fasteners that are attached to the panel out of the door, pull the bottom of the panel out (away from the door) slightly and slide the whole thing toward the back of the door (latch end) and lift up. That top plastic piece is attached to the panel, and clips over the top of the door, sliding it back releases the clips from the door. The triangle piece is held on by bolts, I think 10mm.
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
