spoiler mis aligned?
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
The spoiler on my camaro is off, well not off, but its not aligned.
I dont know what to do. The window looks perfectly fine and aligned but just not one side of the spoiler. Ive attached an image
http://img272.echo.cx/img272/9610/help5ab.jpg
Car: 88 Camaro
Engine: L98 350
Same guy did yours must have done mine at the factory. The window has big holes for the metal trunk lid and spoiler to bolt to. Guess the window is lined up and then the metal panel is put on. It's bolted and glued though, real bear to break loose and fix. I decided to leave mine alone since it doesn't leak.
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: spoiler mis aligned?
Looks like your deck lid needs adjusted, not your spoiler, I had to take my deck lid off not the whole hatch, and resealed it when I realigned the deck lid, the hardest part is breaking the seal from the deck lid and glass,
