Help! 89' Door panel removal...
Old May 24, 2005 | 12:41 PM
FRANKIEINLA's Avatar
How do you properly remove the black plastic "Rail" that runs across the TOP of the door Panel? I practiced at the junkyard and just pulling it up seems to rip the cardboard holes at the top of the panel.
Thanks!
Old May 24, 2005 | 01:17 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I had the same problem. Looks like you need to pop off those black metal washers then reattach them afterwards somehow. I ended up ripping my door panel and had to glue it afterwards.
Old May 24, 2005 | 02:06 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
First you have to remove the entire inner door panel from the door. The window must be down to get the top off. You have to press inward, then up to remove the top rail from the door. Once you have the entire door panel free set it on the ground. There are several inverted sheet metal nuts that attach to plastic studs on the black plastic piece holding it to the cardboard of the door panel. There must be a special tool for that inverted nut, but I haven't found one yet. You can carefully twist them off with Vise Grips. Just be carefull or you'll snap off the plastic studs.
Good luck, Lon
Old May 24, 2005 | 02:54 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I tried pressing inward and couldn't get it off. Then I tried sliding the whole thing toward the back of the door (latch end) and it came right off.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
