Has anyone
Old Jun 7, 2005 | 06:24 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Has anyone
ever converted their drum brake rear end to a disk break rear?
What is needed to make everything work. Giving details would help alot
Old Jun 8, 2005 | 01:30 AM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
i think it would be easier just to find a disc brake rear end from a junk car and get everything you need from there, then it should be easy. if you can find one from a 4th gen they are posi with discs and they stick out a bit so it will make your tires stick out in the back, i dont know if your into that but if you have stock rims it will make it look a bit better IMO...
Old Jun 8, 2005 | 07:51 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Either search or perhaps look in the "brake board". Both would be far more productive than asking about it in the body & interior board. There have been a million threads about swapping to disks and you'll find all you ever wanted to know by searching.
