Bmw Wheels Need Help!!
Old Jun 19, 2005 | 01:08 AM
thirdgenner05's Avatar
Car: 89 t/a
alright Ive been researching and all and found that you are supposed to be able to use a 5 or 7 series bmw wheel for our 82-92 f bodies. I have a 89 trans am and I just hit the ebay scene looking for rims what exactly will I need for these examples to fit my car>?? thanks
http://cgi.ebay.com/ebaymotors/ws/eB...981152312&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...981092349&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...980110903&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...980653979&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...981625532&rd=1
Old Jun 19, 2005 | 11:53 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i didn't do much of a search, hadn't heard of this info before, but i did check out your links. According to the spancing 5 x 120 mm the wheels should bolt up just fine to our lugs. My only concerns would be backspacing (which actually seemed ok) and offset (which seemed different) i'm not sure what our factory offset is, i was only able to compare to aftermarket wheels. IF someone has the factory specs, im sure you can get a better idea as to how they'd sit.
My advice however, would be to get a wheel w/o the BMW propeller on it, as that might seem a little odd. However, if you're planning on removing the emblem, eh, get whichever u'd want.
Good luck, think i might research this a little more myself.
Old Jun 19, 2005 | 03:05 PM
Car: 89 t/a
yeah definitely getting rid of the propeller, but as seen in those links instead of paying upwards of 700-1000 for a set of 18 inch irocs these run at 400 and up, and the used ones are even less.... also I have a buddy with a decal shop and he could make a killer firebird decal to go right over that propeller
Old Jun 19, 2005 | 05:57 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
your fourth link mentions f-bodies specifically
i would take the backspacing and offset sizes from that set and cross reference it with the search feature on this site
you should come up with the answer you're looking for
Old Jun 19, 2005 | 09:00 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Then post your findings here, because I'm interested in this and haven't heard of this before. I'm not really a fan of any of the wheels you picked, but it opens up a lot of new choices for rims.
Old Jun 21, 2005 | 03:35 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
If you do a search over in the appearance forum - it has definitely been posted about before.
It works ok, but is not recommended. IIRC, the BMW wheels are slightly different than GM wheels and therefore there are some issues. I think there was a post over on LS1.com regarding someone who's wheel actually came off.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
