rear discs
Old Jul 2, 2005 | 02:28 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
rear discs
just curious if anyone knows how hard it is to change from drums to discs in the rear?
Old Jul 2, 2005 | 03:12 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
might help to ask on the brake board my friend... anyway one of the mods should move it for you,
to answer the question it's not that hard if you can get the backing plates. then you just need the brake stuff rotors, calipers, pads. You do have to remove the axles though, i believe, which is easy enough to do.
Old Jul 2, 2005 | 05:41 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It shouldn't be that hard if you have a donor car to take all the parts from. Don't forget the rear disc proportioning valve and master cylinder.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
