ground fx 1983 1987 camaro
Old Jul 8, 2005 | 04:27 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
alright, i did some searching, couldn't find much information, so i thought i'd post. I'm thinking i wasn't searching for the rigth info, but if someone could give me a quick answer. A friend needs to swap front clips on his 83 Z28, he found a 87 Z28 in the yards, will everything swap over and bolt up, if things won't bolt up right, where are the trouble spots...thanks.
Old Jul 9, 2005 | 12:03 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
My 89 bird accepted an 82 ta bumper no problem. I think the main thing is if it lines up with your ground effects. The bodies are the same, and I belive any camaro part could be interchanged. Now, camaro bumper wont fit on firebird. Its a bit wider, at least on my bird. So I guess you just have to take the clip and try to eye it or take measurements. Eying should do the trick.
Good luck.
P.S. If the front clip aint much I wouldnt worry about the fit.
Old Jul 10, 2005 | 04:10 PM
sellmanb's Avatar
Car: '86 Berlinetta
the 82-84 camaro noses are slimmer, and sharper angled than the 85-92 noses.
The ground effects wont even begin to look correct. There's a 82 Camaro in the junkyard close to my house, PM me if you want me to grab it for you?
Old Jul 10, 2005 | 04:25 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
ANY 82-92 Z28 nose are interchangeable. BUT, the ground effects. Only the 85-92 ground effects will accept the 85-92 nose and only the 82-84 ground effects will accept the 82-84 nose. You can not put an 85 front ground effect on an 84 nose.
Old Jul 10, 2005 | 04:38 PM
sellmanb's Avatar
Car: '86 Berlinetta
Thanks for clarifying that 84custom
Old Jul 10, 2005 | 08:43 PM
Engine: 5.7
no problem man, glad to help
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
beachrodder
Aug 25, 2015 08:05 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
