how hard is keyless entry?
Old Jul 22, 2005 | 02:15 AM
i_luv_honda!'s Avatar
Car: 1983 camaro z28
Transmission: just got fixed~
im just wondering if keyless entry is something relatively easy to set up and what all i would need to do all this (prices are nice also) thanks
Old Jul 22, 2005 | 10:15 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The wires are all color coded, its relatively easy to intall. SHouldn't take more than 2 hours your first time. All you need is the keyless entry kit and a way to connect the wires (assuming you have power locks). You can either solder the wires and tape them up or get those crimp on splicers.
Old Jul 22, 2005 | 10:52 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you have power locks, its pretty easy.. on the same level as a full stereo install.
if you dont have powerlocks, its the same, except you'll also be adding door lock actuators.
Old Jul 22, 2005 | 02:00 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm going to wire up the keyless entry from a 4th gen in the GTA instead of an aftermarket kit. I have a buddy who has already did this in his 91 Camaro and said it wasn't bad at all. His even flashes the lights and honks the horn.
Old Jul 22, 2005 | 02:12 PM
Firebat's Avatar
dude, thats what i'm planning on doing. However, i have shaved door handles. Just going to use the unlock function to activate the door poppers. I got the 4th gen wiring from my LT1 donor car. I bought a remote off of ebay for $10. Its the way to go if you swapping a 4th gen anyway.
Old Jul 22, 2005 | 02:37 PM
i dont have powerlocks so is it much harder? and whats the general prices?
Old Jul 22, 2005 | 09:50 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
It is not much harder (you have to add actuators like MrDude_1 said). As for price, it depends on what you want to spend (brand and bells/whistles). It also depends on whether or not you want an alarm, remote start, etc. I sold off a pair of actuators I had for $15 on e-bay a while back new.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
