Easy way to replace outer belt molding?(Rubber strip by window)
Old Jul 28, 2005 | 08:07 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just got new outer belt moldings from Classic industries, and I'm having a hard time getting to the screw closest to the front. I need to move the triangular piece by unbolting two 10 mm bolts. There's lots of rust there, so it's annoying. Even when I get those bolts out, I have to pry it out of the way. Anyone know of a eaiser way to do this?
Old Jul 28, 2005 | 08:12 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
i did mine when i had my car painted. i had the mirrors off alltho u may be able to leave em on. the triangle has to be slid out of the way. theres no way around it. for all the other screws i loosened up the window stops on the top of the door so i could pull the window outa the way then just screwed em all in. let me kno if this helps or if you need more info.
matt
Old Jul 28, 2005 | 10:54 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Loosening the window stops sounds like a good idea. I just picked up a longer 10 mm wrench, so removing the passenger side should be eaiser. I just said screw it for the night, and pulled the car into the garage.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
sonu1975
Aug 11, 2015 08:38 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
