How is top of hatch 3rd brake light mounted?
Old Sep 17, 2005 | 11:24 PM
FieroGTA's Avatar
I am considering replacing my cracked aero spoiler with a different style.
That will leave me with no 3rd brake light.
I always liked the look of the high-mount 3rd brake light.
How does the high-mount 3rd brake light attach to the top of the hatch glass on the other models?
Old Sep 18, 2005 | 12:19 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
86 its just two large bolts through the glass. On the early 90s ones I believe its mounted on the inside somehow, so the glass is still a single hole-free piece. The rest had lower mounted third brake lights.
Old Sep 19, 2005 | 01:21 AM
Firebat's Avatar
FYI-
To go 86 style you would have to get a new rear windshield or drill holes in the glass(is that possible?)
To go 91-92 style you would have to get a new rear windshield or remove your rear defrost (too much work if even possible) and replace it with 91-92 defrost if you wish.
edit: not new windshield either could be used...
Old Sep 20, 2005 | 09:01 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
ill trade you, i have the 86 and im dying to get rid of the damn thing.
Old Sep 21, 2005 | 11:06 AM
FieroGTA's Avatar
Thanks for the replies...
I've decided to use a late 1990's Chevy SUV LED 3rd brake light.
http://cgi.ebay.com/ebaymotors/LED-t...QQcmdZViewItem
Simple clean design and mounts flat.
Old Feb 24, 2006 | 08:17 PM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
Originally posted by Firebat
FYI-
I did the research on this... I had a spare defrost hatch from a '83 to put on my '86 and I wanted to keep the high mounted brake light. The glass is tempered and tempered glass can not be drilled, It will crack. What I did was: Cut the post where the bolts go through (which is also where the light gets its power) I soldered a thin 2 wire piece of ribbon cable to the light that came out of the top side of the light through a small hole I drilled next to the weather stripping and sealed with silicon and ran the wires from the back to under the rear head liner trim. I siliconed the bottom of the light down to the glass and used black trim paint to paint the inside of the glass like the original. It worked good I never had any problems with it coming loose or rattling, too bad I never took a pict of it before the car got wrecked
RIP '86 'Bird
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
Omega
Aug 10, 2015 12:46 PM
