firebird door panels in camaro question
Old Oct 5, 2005 | 03:30 AM
sixxerlover's Avatar
Car: 89 Camaro IROC-Z
Engine: V8 350
i have an 84 camaro and am thinking of putting firebird door panels w/ pouch
will any of the 82-92 firebird panel fit perfect and will the armrest and everything else on door from camaro work w/ the firebird door panel?
or will i need to use all firebird door stuff like armrest ect
Old Oct 5, 2005 | 07:48 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It depends on the door panel. The molded GTA-style panels will require you to use the matching arm rest, and arm rest bracket on the door, as well as the piece that goes around the door latch.
Some of the other panels are flat just like the camaro panels, but use the smaller piece that goes around the door latch.
Then there's a bunch of firebird styles that use all of the exact same hardware.
Old Oct 6, 2005 | 12:28 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
91 GTA door panel & cup holder.Original 84 arm rest,trim bezel.There was some very minor trimming required to make the 84 trim bezel fit on the panel,but nothing major.
Old Oct 6, 2005 | 07:14 AM
Jim85IROC's Avatar
Apparently newer GTAs didn't use the "GTA Style" door panel, they used the regular Firebird panels.
Old Oct 6, 2005 | 10:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Are you refering to my panel.That i know of there were two types this & the other with the built in arm rest for the GTAs.I took these off the car myself.Im not a expert though so who knows.Maybe the owner swapped the int.I dont know,but these were on the car & they are leather.So they match the seats.Thats all i care about.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
