Speedometer Swap!!@@##???
Old Oct 21, 2005 | 11:05 AM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
ok, i have searched and searched to no avail. i have an 84 TA with 85mph gage. if i can find one from a similar year with the higher mph gage at the yard can i swap the two. whether just the gage or the whole cluster.
if not what other options are there.
thanks
Old Oct 21, 2005 | 11:28 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
youll have to get one from 82-84 bceause i believe that in 85 they changed to the newer style guages and they were all electronic, yours should be cable driven
Old Oct 21, 2005 | 05:26 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
check out this thread I started awhile back.
https://www.thirdgen.org/techbb2/sho...hreadid=320180
It might be what you are looking for.
Leon.
Old Oct 21, 2005 | 06:02 PM
Orizon's Avatar
Car: 1984 Trans Am
huh, thats all good and well but i was figurin i could find one at the junkyard a lot cheaper then 133 bucks if i could just swap it out. but uh ya, in'n i have to go that route eventually i guess i will but thats a pretty steep price imo. thanks for info.
Old Oct 21, 2005 | 06:21 PM
1tinindian's Avatar
That's the problem with these early 3rd gen firebirds, none were ever offered with anything more than the 85 MPH speedo that was cable driven.
You can always go the 86-newer swap to electric and get the 140 MPH, but that is alittle more involved,(but possible).
It just wasn't the route I wanted to take. My car still has the correct vintage look to the interior, but with an updated speedo face
Good Luck in your search,
Leon.
Old Oct 21, 2005 | 06:50 PM
Orizon's Avatar
Car: 1984 Trans Am
sounds like i will probably have to go the route you went too then at some point. maybe pick up a spare 85 from the yard to throw in while mine is away for two weeks. thanks
Eric2ndGen
Nov 5, 2015 01:51 PM
AUZ28
Oct 12, 2015 08:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
