Stuck Headlight
Old Oct 22, 2005 | 12:22 AM
TransAmman87's Avatar
Car: 90 Trans Am
Stuck Headlight
Hey folks, I was wondering if anyone has had to deal with a stuck headlight (in the down position) on my T/A and what means you went through to get the dang thing out... my headlight motor is most definitely shot, and the bearings inside the unit apparently are gone too because spinning the **** will not raise the headlight. I have no way of getting the whole unit out to replace the motor and I ordered and recieved a new motor! Kinda stuck on this one to be honest, any suggestions?
Old Oct 22, 2005 | 05:05 AM
llvll4l2c91350's Avatar
pretty easy to remove it. 3 long thin bolts. 10mm IIRC. i always use a wrench on those.
also u'll have to remove the nut on the linkage from the motor to the headlight.
Old Oct 22, 2005 | 12:25 PM
Car: 90 Trans Am
Yeah, i finally got it, the motor linkage was stuck, so the headlight was not moving at all, i decided to remove the 3 bolts to the motor and pull the whole assembly out, then i realized the two bolts attaching the assembly to the frame were there, what a pain in the butt it was to get those out. But I finally got it all out and reassembled in about an hour. My headlight works again!... Thanks for the reply!
Old Oct 22, 2005 | 01:26 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
yeh those bolts are a pain the **** to get to. I rebuilt my motors a few months back and when i was done it looked like i was a cutter (wrist was all cut) from screwing the bolts
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
