Doors ?
Old Nov 10, 2005 | 10:25 PM
bbatton's Avatar
Car: 86 Camaro
Transmission: 5 speed
Doors ?
Ok here is my problem I close the doors and every time is sounds like It's closeing in a Tin can! What can I do to resolve this. It sounds like the doors are closeing with out any Door panels on them, is there something I put behind the door panels to quite it down some?
Old Nov 12, 2005 | 03:49 PM
irocyourpants's Avatar
Car: iroc
you probably just have a bunch of crap laying around at the bottom of the inside of the door
just take off the door panel and try to vaccuum up all that crap
also check to make sure everything is "snapped" into place when you have the door panel open- ex. the door lock has a tiny bar that moves to the lock and unlock position-this bar sometimes comes loose and makes noise
hope that helped
Old Nov 12, 2005 | 04:51 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
just take off the door panel and try to vaccuum up all that crap...
I think he means that it resonates when he shuts it (like a hollow metal clanging kinda sound). My old doors did that. You can take the door panels off and put dynamat on the inside of the doors and it will shut with a nice solid thud.
Old Nov 12, 2005 | 09:34 PM
bbatton's Avatar
Car: 86 Camaro
thx guys will check in the Dynamat thingy and check inside the doors to see if anything is loose
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
