Door thud?
Old Nov 16, 2005 | 04:00 PM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
Door thud?
I was pretty impressed with my new GTA at how little it rattled when I got it, but there is one big one that I cant seem to figure out what it is.
It only happens when I hit a fairly decent size bump. It makes a solid thud from what sounds like the door latch/striker bolt area. The hinges are good and the door stays latched good. The rear suspension is nice and solid, the trans crossmember has a new poly mount. So Im fairly sure it isnt coming from under the car.
Have any of you had this problem on your car? If so what was worn out/broken and what did you do to fix it? Thanks for the help.
-Adam
Old Nov 16, 2005 | 10:03 PM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
Nobody's got a thud in their door huh?
Old Nov 17, 2005 | 12:54 PM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
Well does anybody know what exactly loosens up within the door latch that would hold the striker bolt tight?
Is there a bushing or wear part that can be replaced?
Or do I have to replace the whole door lock assembly?
I would like to know what parts I may need before I tear it apart because it needs to sit outside (under a cover of course ) and the doors need to be shut tight. So if I have the parts before hand I can always take something back and not have the door hanging open. Any help anybody can give would be appreciated.
Old Nov 17, 2005 | 03:41 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
do you have t-tops?
do you have power windows?
can u reproduce the sound by banging or "wiggling" the door?
Old Nov 17, 2005 | 04:59 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
It's likely your door pin/bushings. I had this problem with my car. I couldn't figure out where the thud was coming from because the hinges seemed tight when the door was opened. I figured it out by shutting the door with the window open and tried lifting the door. There was enough play that the door would "bounce" over big bumps and give a thud sound. Note: I wouldn't do it when the window was up though. The window put enough pressure on the door to keep it from bouncing. HTH
Old Nov 17, 2005 | 10:59 PM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
I'll have to try that out, I didnt think the window would put enough pressure on it so you couldnt feel it, but apparently it can. Thanks for the replies.
Oh and I have no t-tops, and yes it does have power windows. But I've heard a loose window mechanism before and it doesnt have the sharp chatter sound of a loose window or track.
Has anybody ever had a problem with the hatch pull down motor not holding the hatch tight enough and getting a thud over bumps?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
