Removing center cap embel
Old Feb 7, 2006 | 07:40 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
Ok I done a search but couldn't find anything on this.
How do you remove the embels on the center cap for GTA style rims. I tried everything I could think of and couldn't remove them.
How did ya'll do this?
Reason I want to do this, is to create a custom insert for the center caps.
Old Feb 8, 2006 | 12:36 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I can answer. The center cap with WS6 emblem is attached with silicone. You can pop it off with a putty knife. You can also push from the inside. There are holes that the glue pokes through. You can soak it in WD40 to help soften the glue.
Lon
Old Feb 8, 2006 | 12:38 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I've heated the inside of the cap with a cig lighter, then poke from behind to pop the center off. Becareful not to melt the cap. Just a few seconds of heat.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
3rdgenparts
Aug 8, 2015 07:09 PM
