Twisted sub-frame?pics.
Old Mar 5, 2006 | 04:42 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Is my sub-frame twisted from the PO or is it just something in the door? The door is shut all the way, but theirs still a large gap. Also the windshield is cracked right down the middle, coud this be from sub-frame twist also. What would i do to fix it, before installing SFCs.
Old Mar 5, 2006 | 06:11 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
What makes you say the frame is twisted.Was the car crashed or dropped.If the door is closing correctly or its not hard to close or sounds different than normal.Then your window is just out of adjustment(my 1st guess by the pic).Adjustment is fairly easy after you remove the door panel.As for the windshield what caused it to crack in the first place.
Old Mar 5, 2006 | 06:20 PM
stroker_SS's Avatar
Engine: 355
I wasn't saying it was twisted, that was the question. But i have heard stories of people cracking their windshield because of a lack of sfcs, and this is the reason it is cracked i believe. Also i have heard of people haveing sealing problems because the sub frame twisted.All of this caused from more power than the elasticity of the frame can return to normal.
Old Mar 5, 2006 | 07:58 PM
johnyIROC's Avatar
To bust a front windshield I think you would need around 500RWHP and wrinkle wall slicks... and even then I don't know that it would break. What I have heard of is T-tops shattering from the body twisting...
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
aaron7
Sep 30, 2015 09:15 AM
Breazlan
Sep 25, 2015 11:20 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
