My 'bird's hood
Old Mar 23, 2006 | 08:47 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
My 'bird's hood
I just bought my Firebird, so I am still getting used to it. I have a question about f-body hoods. The hood on my bird doesn't like to close by just dropping it from a foot up or so like most other cars. The latch doesn't line up right. I have to hold open the latch and then set the hood down where it would be if you had just popped it from inside. Then I have to force it to closed by pushing down on it with quite a bit of force. I am afraid of damging the hood over time, is this common on f-bodies? Or is something wrong with the latch or something. Thanks guys!
Old Mar 23, 2006 | 10:29 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I could be wrong, but maybe it just needs some more grease? I know that mine had trouble popping up so I applied grease and it's much better.
Old Mar 23, 2006 | 11:47 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
No my problem is not with opening it is with closing. The latch doesn't seem to line itself up with the hole that it locks into unless I manually hold open the latch and force the hood shut.
Old Mar 24, 2006 | 12:51 PM
Car: 1994 Trans Am
Right. But if there's no grease to slide on, it will catch the metal frame instead of sliding and hitting the lever.
Old Mar 24, 2006 | 01:38 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
The hinges that the hood attaches to the fender with can be loosened and this is how you line up the hood. The latch bar on the hood itself can also be loosened and aligned with the latch. And last but not least the latch can be lined up also by loosening.
Old Mar 24, 2006 | 02:55 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Oh okay. Thanks, I didn't know that.
Old Mar 24, 2006 | 02:57 PM
Engine: 355 chevy
np, thats why we are all here to help eachother out!
Old Mar 24, 2006 | 03:53 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Okay, I have to apologize. After re-reading your reply and going out to my car I realize what you meant and yes I knew that was possible, but that's not my problem. I think I'm just not communicating my thoughts very well, I should have called it the release latch. I have attached some picutres to illustrate. One is a picutre of the release latch which has no method of adjustment that I can detect, and one is of the same latch with the hood lowered. You can see by how far the release latch misses the hole.
Attached Thumbnails My 'bird's hood-100_0047a.jpg   My 'bird's hood-100_0043a.jpg
Old Mar 24, 2006 | 05:13 PM
Engine: 355 chevy
hmmmm that is interesting, maybe the car was in a prior accident? I'm not sure what to do unless I was there. Sorry
Old Mar 24, 2006 | 05:14 PM
Pocket's Avatar
Car: 91 Trans Am
2 of my brids did that, just something I got used to
Best I could ever figure, the safety/release latch was bent cuz of someone slamming it shut and the hook snagging and gettin pressed by the weight/momentum of the hood
Old Mar 25, 2006 | 08:01 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
when you close your hood is it closer to one of the fenders than the other than you make an adjustment on the striker on the hood that looks like half a swatchtica. bad spelling. if not you can adjust the actuall locking mechanisim I think it is two bolts.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
