question for anyone who knows how to do custom fiberglassing?????
Old Mar 27, 2006 | 06:07 PM
ChevyRS-305's Avatar
I am redoing the entire interior on my car IN FIBERGLASS!!!!!! I came across some complex curves I need to have in order to make the dash, rear panels, ext to “flow like water”. Most of the time the fleece can give me this curve but this is a whole different story!!!!! I was thinking of using chicken wire(the one with tiny holes) to get me this curve, but I have so many multiple curves to deal with, it will be extremely hard to bend the wire this way, I could do this but it will take forever to do….. I want to know what some of you use for this problem or if anyone has a better suggestion to this problem?
also if you want to know what i want it to look like look at the interior of an Aston Martin
Old Mar 29, 2006 | 02:02 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
spandex
Old Mar 29, 2006 | 02:10 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You use fleece by stretching it over the shape you want. As you've discovered, it only works for convex shapes. If you want to make a concave shape, make another template that attaches from the front to push the fleece where you want it to sit. Once you're happy with it, remove it, wrap it in tin foil and spray it with cooking spray or mold release, get the fleece soaked in resin, then reinstall the piece to push the fleece where you want it.
Another option is to carve the shape you want out of foam, cover it in foil, and 'glass right over it.
Old Mar 29, 2006 | 05:17 PM
Where do you think i can get a piece of foam that is at leats say....as big as the whole dash!!!!!? They dont have it at walmart...lol
Old Mar 29, 2006 | 05:34 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
you can go to homedepot and get large thick sheets of foam. Then bond them together to make a BIG piece.
Old Mar 29, 2006 | 07:23 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
You can also use a 2 part foam...make it whatever shape you want. It sets up quickly too.
Old Mar 29, 2006 | 08:01 PM
Jim85IROC's Avatar
Plus that stuff will be rigid enough that it will be easy to shape. If you try to shape the soft squishy crap from Wal Mart or Jo Ann Fabrics you'll go nuts.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
87iroctheo
Dec 4, 2016 11:47 AM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
