Hood stuck?
Old Apr 5, 2006 | 02:43 PM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
Hood stuck?
Well I went by a junkyard today...they had a fiberglass hoof on a 3rd gen firebird I wanted to pick up. Well, I leaned in the car to pull the hood latch thing....and the entire thing pulled out....so I was kinda worried at this point...went to the front and could not get the hood to come up...
Is there a way to get the hood off without damaging it?
Old Apr 5, 2006 | 02:49 PM
KissThis's Avatar
Car: 1984 Firebird V6
You will probably have to crawl under the car and work on the latch a bit. Take some spray lube. You may end up taking the entire latch off. You may have to jack the car up to get under it.
Old Apr 5, 2006 | 05:33 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
my girlfriend had this same thing happen in her s-10. we just took a pair of vice grips and pulled on the lever where the hood pop used to be. did just the hand latch part break off? does it have a metal rod behind it? if it does just take some vice grips with ya.
Old Apr 5, 2006 | 05:41 PM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
I was hoping for that to work...but i pulled that panel off and pulled the metal rod...only for it to pull out of the car...so I was very dissapointed. Im gonna give it a try in a few days, see if I can comeup with something
Old Apr 5, 2006 | 05:45 PM
purpleZ-28's Avatar
oh, wow. the whole thing is gone. well...
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
