taking off the door panels. help please
Old Apr 8, 2006 | 06:59 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i need to replace my passanger side mirror. what is the easy way to take off the panel. is there anything i should look out for. thanks
Old Apr 8, 2006 | 09:36 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
get a long flat blade and easily pry the panel away from the door. First you have to remove the arm rests and plstics. The panel is held on by plastic rivits, you might break them, no big deal, go to autozone or advance and get some more from them. They WILL break, so dont feel bad.
you also have to remove the outer weather stripping which has a few small bolt type screws, once you do that, you can get at the mirror. The mirror is held on by 2 nuts.
It's been a while since I did it. I simply left my mirrors off. Personally, I dont want to see the cop behind me!
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
AkDrifted
Aug 17, 2015 07:45 PM
BrianI
Aug 9, 2015 11:52 AM
