I have a question for those who have used POR 15
Old Apr 14, 2006 | 07:33 PM
jonarotz's Avatar
Car: 91 Z28
I am going to be using some POR 15 in my engine bay and I was wondering if I need to spray my top coat over the POR 15 while it is still tacky? Can I spray my color on after the POR 15 has dried with success?
Old Apr 14, 2006 | 07:48 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I would wait at least 24 hours before paint is applied. It worked out fine for me this way. I went on a friends advice, he was right in my case. The paint looks great.
Old Apr 14, 2006 | 08:04 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
POR-15 says to apply the top coat while the POR-15 is still a little bit tacky. Otherwise, you should use a special primer from the company before you apply the topcoat.
POR-15 dries pretty smooth and hard, so if you wait too long the topcoat may not have enough "tooth" to grip onto, and may not last as long.
Old Apr 14, 2006 | 08:09 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
In my case I used the primer. Forgot to mention that. So I guess either way will work. If you spray while tacky you can save $$$$ on(not buying) primer !
Live and learn. Next time.
Old Apr 14, 2006 | 09:02 PM
jonarotz's Avatar
Car: 91 Z28
Well I don't have the top coat yet and I want to make some progress. I will probably just buy thier primer it is less than $20 for a pint.
Old Apr 16, 2006 | 11:18 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I personally would not por 15 an engine bay. Someone on this board did it and it looks bad in my opinion.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
