Dye or paint ?
Old May 23, 2006 | 07:09 AM
yousuredo's Avatar
Car: 84 z28
Engine: 305 HO
Dye or paint ?
what is the best way to restor the original plastics ?
how durable is either going to be ?
Other ways to do this ?
before you flame me about doing a search, I have been trying and it keeps telling try again later...
and I have read several pages back, with no results....
thanx for your help !
chris
Old May 23, 2006 | 07:16 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
"Dye" and "paint" is pretty much the same thing when it comes to plastic panels. A plastic or vinyl "dye" is still designed to be sprayed.
There are a million brands out there, and I've found the SEM to be the best. It gives the most natural appearance once it's applied, and seems to be the most durable too.
I've used Plasti Kote, and had good results with that too. It doesn't lay down as smooth as the SEM, but over textured surfaces that doesn't matter. They have a color that's a spot-on match for the generic gray color in a lot of the thirdgens.
I've used duplicolor and haven't been as impressed, though again, on textured surfaces, it's not real likely to matter.
I'm not a fan of the Krylon Fusion. Too thick & heavy even on textured surfaces, and it's too damned shiny.
Old May 23, 2006 | 07:49 AM
yousuredo's Avatar
Car: 84 z28
Engine: 305 HO
thank you, I will check into that !
Hotrodboba400
Dec 10, 2019 07:07 PM
starliner
Feb 9, 2016 08:18 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
