doors
Old May 23, 2006 | 02:52 PM
bbatton's Avatar
Car: 86 Camaro
Transmission: 5 speed
doors
Will any door from a Firebird,TA fit on a camaro? and also does the front left and right fenders bolt up too!
I found a TA that has no motor And he said the 5 speed trany is good All I need from this car is the driver's side door and the rest I will part out, He will sell it to me for 250.00 and the body is in excellent shape.
Old May 23, 2006 | 03:07 PM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
The fenders wont work on a camaro due to a diff slope. You'd see it if you looked at the two fenders dead on.
The doors are the same between the two as far as i know, i believe the only difference is the interior trim/door panel.
Old May 23, 2006 | 03:26 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
the fenders will technically bolt on to the frame (Transcamaro) but are different as far as looks and what not. I say buy the car for cheap and put a new motor in it and get a new doro elsewhere
Old May 23, 2006 | 09:14 PM
blizzard's Avatar
Car: 86 T/A
Engine: 383 stroker N/A
Transmission: th350
Axle/Gears: 4:11
doors will fit but molding on exterior is different
Old May 24, 2006 | 07:28 PM
bbatton's Avatar
Car: 86 Camaro
Are you talking about the removable molding?
So If I remove the molding then all is same?
Old May 25, 2006 | 02:04 AM
1989karr's Avatar
Engine: 3.4 / 5.0
I believe he is talking about the ground effects. The Trans Am has ground effects and they are different from the camro ground effects. Base Firebirds don't have ground effects and they don't have the bracket for the ground effects either.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
