weatherstrip adhesive!
Old Jun 4, 2006 | 10:38 AM
gon8go's Avatar
Car: 89 trans am ws6
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
I finally got my t-top weatherstrip kit and center molding from f-body motorsports. Is there a chemical to remove adhesive from old stripping and what should I use to set the new stuff in?
Old Jun 4, 2006 | 10:51 AM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
well what i did is just remove the old glue with ur fingers and when u have it clean then use some weatherstripping adhesive, make sure u dont buy the cheap stuff. big mess if u do.
Old Jun 4, 2006 | 11:18 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
3M sells an adhesive remover that works pretty well, but brake clean has always done the trick removing adhesive if the area cant be affected by the brake cleaner or isnt visisble...wouldnt want to fade or remove paint or fade plastic using it somewhere more visible.
Old Jun 4, 2006 | 11:57 AM
gon8go's Avatar
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
is there any particular brand of adhesive to get?
Old Jun 4, 2006 | 12:13 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
I like 3m
Old Jun 4, 2006 | 12:28 PM
dacboyz's Avatar
Car: 89 Camaro
I also have used 3m. No problems.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
