94-97 V6 Wiring Schematics / Compatibility
Old Jun 21, 2006 | 06:31 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i asked this in another post but noone seemed to be answering. i just want to know if i can use a v6 cluster wiring, and put in a v8 cluster?
is this possible, and if i had 94-97 cluster wiring/connector will an ls1 camaro cluster plug in and work?
basically first priority i need to know if there is a difference between the cluster connector for v6 and v8
Old Jun 21, 2006 | 07:16 PM
Faded's Avatar
Car: '91 Firebird
I was able to use the same plug between a V6 and V8 fourth gen camaro cluster. The actual plug was from the V8 though... the V6 plug probably has less wires.
Old Jun 21, 2006 | 07:52 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
less wires, why would you say that?
Old Jun 21, 2006 | 08:00 PM
Faded's Avatar
Car: '91 Firebird
Because V6's typically came with less options.
Old Jun 21, 2006 | 08:32 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
could you be more specific... would it be worth getting the connector, the guy wants like 10$ or something...
Lowrider0308
Feb 5, 2015 11:41 PM
84redta
LSX and LTX Parts
Mar 13, 2011 12:50 PM
jagevileye21
May 15, 2009 02:54 PM
