90 doors on a 91 rs ??
Old Jul 31, 2006 | 06:16 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Can someone please advise if 90RS door will fit on a 91RS.
I am trying and neither side wants to close. They both drag badly and did not on the original car(90rs) .
Old Jul 31, 2006 | 06:36 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
All third generation F-Body doors are interchangeable. That means (for example) you can take the doors off an '82 Firebird and bolt them to a '92 Camaro. If it's dragging then you need to do some aligning or give us some more details on your project so we can help. And do you still have the 1990 GFX on the doors. They're different from the '91 versions and may cause some clearance problems.
Old Jul 31, 2006 | 07:23 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Thanks for the fast response.
I did change the GFX from the 91 onto the 90 doors but they were so dragy i took the GFX off.Still doors wont close without a GOOD lift and SLAM.
Are they adjustable to any extent ? It did not look like there was any slots or over-size holes.
Old Jul 31, 2006 | 07:45 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
they are adjustable but i would check to make sure the hinge pins are still good and replace if neccesary....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
