What trunk lock??
Old Sep 6, 2006 | 09:27 PM
Ironmahn's Avatar
Car: 1986 Trans Am
What trunk lock??
I have a 86 Trans Am and noticed something that seemed odd to me. In the rear of the car where the taillight assembly and center section is located there is a hole that is used to access the lock for the hatch, easy enough. Well there is no lock or hole in the body, nothing. The car has the power release/close trunk and there is a wire that can be pulled from the inside to open the trunk, I assume in case there was no power. Is this a common thing with these cars or did someone make a boo boo at the factory,?
Old Sep 6, 2006 | 09:30 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
there's no hole through the sheetmetal for a lock? have you taken the interior and tail lights out to check? because there should be one there. if there is just a wire to pull then your lock was broken off. but there should definitely be a hole through the sheetmetal
Old Sep 6, 2006 | 09:45 PM
Ironmahn's Avatar
Car: 1986 Trans Am
Nope no hole, looking through the hole from the outside of the center section you can see the paint of the car on the sheet metal. I have taken apart the interior to access the assembly. The wire is a heavier silver braided wire apprx. 1/8 in. diameter that appears to have been factory attached. The wire has a little lead ball or some other metal crimped on the cable that is fed through a hole on the release lever of the assembly. Sure looks factory to me .
Old Sep 7, 2006 | 07:51 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
That cable attached to the inside of the lock cylinder. The other end connects to the pull-down motor with either the manual hatch release (black in color) or a electric solenoid release (silver in color). The releases are attached with a 10mm screw. At one time your car had a key release.
Lon
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
