Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
Re: Phase I complete, now Phase II IROC restoration - on to the interior!
this goes far back but the new corvettes have a emergency release in the hatch that you can pull to open the doors (they desided to remove the jump box off a vette at work when i was in it but i knew about the release) its just like the hood release its on drivers side rear maybe you could do something like that?
being locked in or out of a car is kinda sucky lmao if the battery went dead
You did what i wanted to do with the gap on the strut mount sheet metal to inner fender sheet metal did you weld it up then grind it down and bondo it ?
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Thanks all for the compliments,
I was pretty stoked when I got the tail lights mounted! Having the lights on makes the car look more complete. Oh, they are the original tail lights, not new. Supreme Member
Car: Faster
Engine: Than
Transmission: You!
Your GM LS-1 harness should be in on Monday or Tuesday. I call you when I go down to pick it up.
It's starting to look like a car again!
You'll still need a factory LS-1 ECM from an '02. Chris will hook you up with the owner of MTI to tune it. Jason can tune the factory ECM to run that motor no problem that way we can start it and drive it. Then he'll wide-band tweak it on the dyno. You won't have to go the DFI route. Save the DFI $$$ for the T-56.
Mike
Mike
Car: '87+'02 Z28
Engine: 454 LSX
Today's progress: Cleaned the dash and center console and then dyed it a deep, satin black. I didn't dye the air bag lid so you can see the difference......i'll have to get a new one b/c this one is cracked.
Car: '87+'02 Z28
Engine: 454 LSX
and I installed the clutch master cylinder and drilled the holes to mount the gas pedal bracket. That's it for now, gonna take a break and maybe get back at it later this evening.
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
I hope you have all of those wires labelled
What are the strut top mounts you are using?
Car: '87+'02 Z28
Engine: 454 LSX
Car: '87+'02 Z28
Engine: 454 LSX
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Neil,
Very awesome work so far. This is definetly going to be one of the finest 3rd gen examples around! Ide feel comfortable calling it the best modified thirdgen Ive seen. Great work!
One question... You do awesome work, and its obvious you have skills...but how the heck did you get the master cylinder to line up so nice??? I measured and checked and all that before I drilled the holes for mine, but it still came out with the rod goin in crooked. I had to modify my holes to make it better, but it still isnt perfect.
Any tips for setting that up? Tweaks to the pedal brackets, spacers, etc etc??
You can PM me if you want so you dont have to clog your thread up with it...
Thanks!
Justin
Thanks!
Justin
Car: '87+'02 Z28
Engine: 454 LSX
Neil,
Thanks!
Justin
Thanks!
Justin
I think it's gotta be a slight difference in the mounting surface on our firewalls relative to the 4th gens which is why the clutch rod doesn't line up perfectly, you agree?
Car: Faster
Engine: Than
Transmission: You!
Nope, I don't agree...... I've installed all 4 of my conversions straight!
You have to get the rod as close to perfect as you can otherwise when you step on the clutch you will bend that rod. It's not as strong as it looks.
Car: '87+'02 Z28
Engine: 454 LSX
Kiss my A$$ lol.
If you wouldn't have mangled the pedal assembly you got me than probably mine would have lined up too
. Perhaps the rest of us are getting pedal assemblies that are slightly missaligned because my holes were marked perfectly to the alignment of the bracket holes and the rod is not perfectly straight like you think it would be. Nevertheless it won't be a big deal to get it straight. Joined: Sep 2002
Car: 86 Trans AM
I drove mine around fine. That rod is pretty strong, and even at my angle there was no way it was going to bend... Either way, Im not using the stock rod...so I guess I cant vouche too much for it anyhow. Stocker is a two piece deal, mine is solid with a rod end on it.
My pedal assembly was out of a A4 to M6 swap car also, so Im not sure if it was tweaked, but it definetly didnt just line up to my firewall. It was wayyyy off at first. Then I tweaked, and its where it is now. Still with a slight angle. Its SO frustrating because Ive heard of people just dropping it in and having it work. I guess on some cars it falls in place and in others it doesnt...
Anyway, thanks for the info!! Keep up the good progress on that sucker!
Justin
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
My car had a T-5 and I dropped a T-56 in it and that rod lined right up with my pedals. Are you guys just talking about auto cars, that need drilling? (I would assume you are)
Car: 86 Trans AM
Justin
Car: Faster
Engine: Than
Transmission: You!
lol
Haha... Was just giving you crap! The brand new assembly I got you was not mangled you terd!
I do think the firewall on the inside of a 4thgen is different than a 3rdgens' (proof is in the gas pedal allignment). That's why I suggested to use the 3rdgen gas pedal.
FYI for those who care:
The factory two piece clutch master cylinder is weaker than you think. I had to make a new firewall plate and reallign a NEW master cylinder for a customer's car that attempted the conversion himself. He had the rod at a slight angle and after a few months of him driving the car, the rod snapped.
From memory, how I set it up :
I didn't use the brackets to draw out and drill the 2 holes. I removed the bracket arms and made my own template and brace. For the center oval, I used the correct size hole saw to make the top and bottom of the oval, then I used a dremel tool to cut the vertical lines (if that makes sense). The clutch master cylinder rod is perfect allignment to the center of the cylinder the whole stroke of the clutch pedal on the conversions I've done.
But anywho, I think the bracket hole on the left side (driver) is accurate and the other hole on the bracket arm (torwards the console) is the one that is off. Make a U brace/ for the two bolts that way you don't flex the firewall as much.
I called GM today, your harness is on a 1 to 2 week back order. If I get a VIN for an '02 with an LS-1 / Six-speed, I can speed up the order and be 1st in line. Jim's son has an '02 SS with a six-speed. I'll see if I can borrow his VIN.
I don't hear that thing runnin' yet, get that *** in gear!
Car: '87+'02 Z28
Engine: 454 LSX
lol
. Just giving you a hard time, freakin, mangling my parts, lol. Anyway, when I put the Mcleod clutch in with the Mcleod clutch master cylinder i'll line that biatch up! Supreme Member
Car: Faster
Engine: Than
Transmission: You!
Hey just keep in mind, I'll have a harness to mangle soon, so better shape up yo!
What did you use to dye it black? It would make my search for fourth gen parts a lot easier if I can just dye them black!
Car: '87+'02 Z28
Engine: 454 LSX
I used Color Coat by SEM, Satin Black #15243. You can also buy a adhesion promotor made by SEM, but I didn't do that and I never have. I have just made sure the surface was as clean as possible.
Car: Faster
Engine: Than
Transmission: You!
You will be much happier with an exedy twin disc, it's WAY better than the Mcleod. I think it also comes with an adjustable master/slave and an aluminum flywheel. I forgot to get a part number and price when I went to Jim's on Monday. I'll get it next time when I get the VIN.
Sweet progress Neil!! Tell your man to stop mangling the parts......LOL. What's up Mike?? Neil said he wanted you to come and help him hold up the dash...Car is looking really good. I still can't get over the 335's. They are going to leave a sweet patch! Can you say YouTube video???
Car: Faster
Engine: Than
Transmission: You!
Whats up!
Mine's almost drivable again. Going to hang the rebuilt rear and suspension today. Hopefully next weekend it'll be drivable again. I still need to see you about detailing the ride as soon as it's up and running.
Neil - I got the part number for your clutch. Jim will have a price for you on monday. It's NOT cheap .... holysh*t !! It retails for $2,899.00 !!!
Of course he can get a major break on that though. It's a twin disc stage 4 Exedy and I'm pretty sure it comes with an aluminum flywheel and an adjustable master/slave. But for that price, it should also come with a blonde bimbo and 6 winning numbers!!
Car: '87+'02 Z28
Engine: 454 LSX
With the generous help of a friend of mine from work, we were able to get the dash in the car and test-fitted. This is definitely a two man job! After holding the dash up, both brackets close to both doors had to be completely removed. Notching them out as was done by another member in the 4th gen dash sticky, wasn't working for me...so the air cut-off tool and the Rotozip had a little party.
Thanks Bob!
Thanks Bob!
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
i'm movin out to texas near houston to go to uti in october, maybe i'll get a chance to see the car around sometime!
Car: '87+'02 Z28
Engine: 454 LSX
More photos to show how the dash mounting tabs are flush with the metal lip (I did have to drill holes about 1/2" wider than the existing holes).
Car: '87+'02 Z28
Engine: 454 LSX
Crap, sorry about that........accidentally hit enter! Ok, so the outermost upper mounting tab on the drivers side is about 3/4 - 1" away from the mounting surface (middle pic). Once I have the A/C box installed and the lower dash mounting brackets fabricated and installed, i'll then determine what spacer, if any I will need on the drivers side upper tab. The drivers side, lower mounting tab will take some work as it is in the way of the hood release. I'll have to see what the other guys have done, unless someone has an idea.
Car: '87+'02 Z28
Engine: 454 LSX
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Neil, what do you plan to do with the gaps on the left and right sides by the doors?
Car: '87+'02 Z28
Engine: 454 LSX
Engine: LS3
I see you are having problems with that hood release. I think I can shed some light on that. It all depends what you wanna do. I personally always like how the old school car guys just reach up under the nose, and pull down. (when outside the car) so thats where I relocated mine. Granted I just have a hole where the old one went, for now. I have my entire interior covered in cloth, so I plan to just cover over the hole in the kick panel and and forget about it.
I can get pics of you want. Lemme know.
http://www.ms-fbodies.com/jade_ta.htm is a great resource, he has no gap with the 4th gen dash.
Car: '87+'02 Z28
Engine: 454 LSX
Neil - if you use the 4th gen kick panels they should fill in the hole.
Car: 87 GTA
Ever figure out what you are doing wit the new space between the tail light housings and the license plate?
Car: '87+'02 Z28
Engine: 454 LSX
looks like it, click this https://www.thirdgen.org/forums/atta...ctures-016.jpg
Car: 87 GTA
Nope. That is stock. The space between those black panels is now about 1.5" wider, per side, than the license plate. So, there is a gap between the plate and those black pieces.
Here is another pic, showing the gaps...before the paint was put on.
Car: '87+'02 Z28
Engine: 454 LSX
Here are some not so exciting pics pics of the modified ducting behind the 4th gen dash. I got some very helpful photos from 'Faded' on cutting the 4th gen ducting. Next, i'll epoxy small pieces of plastic on the smaller ports to achieve a proper seal. Pic on the left (before cutting), pic on the right (after).
Car: '87+'02 Z28
Engine: 454 LSX
The pic rwdtech posted is not of my car stock. John cut a piece of plastic to cover the gaps on both sides, which goes behind the license plate (obviously no license plate in these pics).
Car: 87 GTA
Well,the gap is still there, is what meant. That just eliminated any body color showing of the sheetmetal. Still stock housings.
I'd get another set of inner black pieces, plastic weld them together, smooth and sand them, then paint them a semi gloss black, so they appeared stock, just wider.
I'd do the amber to red turn light lenses conversion too.
Just my 2 cents.
Just my 2 cents.
Looking good Neil!
For those of you in suspense for the airbox, here's a photo I sent to Neil a couple days ago.
Car: '87+'02 Z28
Engine: 454 LSX
You guys must be getting bored of these pictures, but here is the 2nd layer of Dynamat, 'Dynapad' going on the firewall. This stuff weighs slightly more than the stock rubber padding and is easy to work with. I've been using Gorilla glue to hold the Dynapad down on the sharp turns and the stock plastic retainers are working well also. Tomorrow I will finish modifying the 4th gen ducting and then by the weekend i'll have the dash in the car with all the duct work installed.
Car: '02 Z06
Neil did you buy that Z28 emblem with the red bowtie or was it custom made? It's a nice touch..
Car: '87+'02 Z28
Engine: 454 LSX
Car: '02 Z06
That's what I figured.
Thanks for the compliment! Can't wait for completed shots of your car.. should make for some awesome desktop material!
Car: '87+'02 Z28
Engine: 454 LSX
Thanks again!
Well, can't seem to get off the computer. I was working on the car til about 10:30, then did some real work, posted some pics. What are you doing up? Wait, let me guess.......ebay!
