Frankenstein T Tops?
Old Oct 27, 2006 | 02:52 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have never taken a T Top mechanism apart before. I am wondering if I can take two T Tops, one being a Lexan top with large attaching pins and the other being a glass top with small pins and combine them to have a Glass top with the large pins. Can they be taken apart in such a manner?
Old Oct 27, 2006 | 05:14 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Well, I would put one of each next to each other and start taking them apart. I'm thinking the mechanisms would switch up. I'm thinking it could be done, but I dunno 100%. I do remember seeing some rivits in there somewhere. But I think they where holding the lock in place.
Good luck and let us know
Old Oct 27, 2006 | 05:34 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Its tough because I need to know before I make a purchase. I'm hoping somebody can tell me...
Old Oct 27, 2006 | 05:40 PM
Pocket's Avatar
Car: 91 Trans Am
Yes you can, the cover is held on by a few screws and then you can swap all the guts of the unit easily
I had to swap a large pin glass to small pin to replace my small pin lexans
Additionally, large pin is only a fat piece of removable plastic on the end of the pins, take it off and viola you got small pin again
Old Oct 27, 2006 | 08:26 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Making the swap is simple. Leave the t-top alone, no Frankensteining necessary. Just get the proper sized retainers, the 4 things that bolt to the car's roof that hold the t-tops in place. Remove your old ones (two small screws/bolts) and install the new retainers. Voila, done. You know the pieces I am talking about?
Old Oct 27, 2006 | 08:43 PM
krisb410's Avatar
That does seem to make more sense
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
