Window/T-top weatherstrips
Old Nov 11, 2006 | 02:05 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Not sure if this the right forum, but it seemed most appropriate here.
The question is, where would be the place to get them? I need the ones that mount to the outer part of the t-top and possibly the entire window kit. I want them to fit right the first time and have no need to be cut or stretched. Are the OEMs really OEMs? I've found them on HawksThirdGen, ClassicIndustries, but can't find them on GMPartsDirect. I wanted to get them from GMPD, but I couldn't find it with their catalog. Thanks for any help.
Old Nov 11, 2006 | 07:57 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I found a full 8 piece set on eBay for auction that I won for $255. Search around and you might get lucky.
Old Nov 11, 2006 | 08:16 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Found this set on eBay.Know what seller you bought them from?
How did it fit?
Old Nov 12, 2006 | 12:10 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
That is different than the 8 piece set I got. That is SoffSeal, not original GM. The GM kit comes with the two long strips for the windows/T Tops, then the 6 pieces required to put new weatherstripping on each of your T Tops. I have no experience with SoffSeal stuff.
Old Nov 12, 2006 | 11:49 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Ok. Thanks. I'll try to find the GM. I hope I can find a kit with the rear hatch seal. It's leaking too.
Old Nov 12, 2006 | 02:04 PM
91_T/AWS6's Avatar
Car: 91 Trans Am
check out fbodymotorsports.com They have GM brand which is kinda pricey and they got a restoration part brand that GM has licensed with their name that is a little less in cost. I'm sure you'll find what you need up there. They are kinda slow on shipping though, it took me a little over a month to receive my weatherstripping.
