power windows
Old Nov 21, 2006 | 04:15 PM
sfusco3's Avatar
Car: 91 firebird, 89 trans am GTA
power windows
suddenly my windows aren't working anymore. I checked the fuse at location 15 35 amp fuse and it is ok. does anyone have any ideas I what it could be.
Old Nov 22, 2006 | 01:56 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Window motors?
Old Nov 22, 2006 | 08:43 PM
Frank89IROC's Avatar
Since the fuse is good then you have to check if there is current getting to the switches on the console, you'll need a "test light" or "volt meter". If there is current at the switches (with key on) you'll have to check if current is getting to each motor when you press the switch. Take it from there. Could be in the wireing or the motor(s) themselves although I doubt both motors would fail at the same time.
Have you recently spilled a soda or other beverage on the console near the switches? That would cause the switches to fail.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
