Hatch trim piece is oxidizing...how to replace?
Old Dec 2, 2006 | 10:17 AM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
That little metal trim piece around my hatch window is kinda oxidized on the one side and a tiny bit of rust is beginning to show through. Basically can you just buy a new piece? If not, does it even come off the car so that i could repaint it myself?? Or do i have to like paint it while on the car (which might not be the best idea....)
Old Dec 2, 2006 | 11:01 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Maybe You could try sanding it down and touch it up with a paint marker...
Old Dec 2, 2006 | 11:49 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
it comes off the glass but taking the glass off isnt fun then you have to realign it to get it back on right well that was my case when i took my hatch off anyway. but i would just sand it, tape it, and paint it
Old Dec 2, 2006 | 12:15 PM
a mack6's Avatar
hmm..is there a way to like use a brush and paint it so it looks good or is my best bet spraypaint??
Old Dec 2, 2006 | 05:08 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Spraypaint's your best bet and can turn out looking pretty good, I wouldn't try to make a big job out of it, like said, sand it, tape it, and paint it. You can use a little etching primer(in a spraypaint can) to make it stick well and hold uo too.
Old Dec 2, 2006 | 05:25 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
the word 'like'
Don't mean to be petty, but with every girl the the country seeming to say 'like' every second word, is it necessary to TYPE the word into 'like' every sentence?
Old Dec 2, 2006 | 05:41 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I guees you can take off the plastic piece rectangular piece on hatch when you open it kinda hard to explain in words, and i guees there is bolts under that that hold it on or at least thats what I've been told Im in the same boat as you and ill find out if this is true this spring when I go to attempt this
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
