Wanted................................
Old Dec 14, 2006 | 10:12 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Considering i can't post in the classifieds section i'm going to ask here....
I am looking for a 1982-1992 Camaro that needs some work and is fairly cheap or doesn't need work and is cheap. I am in NY in the Canandaigua area. Zip code 14432. Thanks alot
Old Dec 15, 2006 | 03:56 PM
v10viper04's Avatar
Engine: LT1, L99
anyone have anything?
Old Dec 16, 2006 | 07:05 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
why can't you post in the classifieds section? you can check out www.newyorkfbody.com, it's based in the buffalo area so you might find something not too far from home
Old Dec 16, 2006 | 08:31 PM
MavViper's Avatar
Someone should be here shortly to move it to the classifieds, but that's odd how you can't post in the classifieds section.
Old Dec 16, 2006 | 11:35 PM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
I can't post in the classifieds either.
Just thought I'd throw that in there.
Old Dec 17, 2006 | 12:27 AM
JT's Avatar
JT
Community Administrator
If you can't post in the Classifieds section, please review this thread for some information:
https://www.thirdgen.org/forums/prob...able-post.html
In short, you must either be registered for over 30 days, or have 30+ posts, in order to post on the Classifieds section.
However, if we are contacted, we do make some exceptions. v10viper04 already as permission to post in the Classifieds since you already have met the 30 post minimum requirement.
19 z28 92, I have updated your account so that you can post in the Classifieds section.
With all that said, this thread will be locked since it doesn't belong here and the case is closed.
JT
