Back Hatch???
Old Dec 29, 2006 | 11:36 AM
airjordan6906's Avatar
Car: 1988 camaro rs
Back Hatch???
My back hatch keeps leaking and water is getting to my subs and donn't know how to fix it any ideas???
Old Dec 29, 2006 | 11:43 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
get someone inside, looking in the hatch. Get a hose and soak the hatch....soak it until the person inside see's where the water is coming from. It could be your hatch out of alignment or a crappy seal.
Old Dec 29, 2006 | 12:23 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
If its not too much trouble, pull ur subs out while doin it. But sickness is right, its the easiest way to track it. What condition is the seal in? If its rough, good chance its whats causing it.
Old Dec 29, 2006 | 01:16 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Originally Posted by Sickness91Z28
"If you didn't build it with your hands, you can't call it yours"
Aint that the truth.
Old Dec 29, 2006 | 04:37 PM
84CamaroSS's Avatar
Car: 1984 Camaro
Engine: 350 bored .30 over
Transmission: TCI 700-R4
Axle/Gears: Stock 3.23 i think
I had the same problem and i fixed it two days ago. Do what they said if its the weatherstriping replace it. Oh but first remove the little piece of plastic from the hatch lid. Mine was leaking where the glass runs into the hatch plate. I ended up removing th elid and scraping off all the black sealant. After that i applied all new sealant. Forgot what it was called but its like a glass sealant. Make sure you soak it in hot water for like a half hour at least. Pain in the *** to sqeese out trust me. Apply the sealant to the top of the valley and the bottom. Youll know what im talking about when you get it off.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
