Got backed into... How does this piece come off?
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
Someone backed into or ran into my car in a parking lot... thank god i was waiting to get it painted... here are some pics, how do i take the body molding piece off? can i find a used one and put it on or do i have to go with a brand new one from gm?
and the dent is not a crease so it seems as if its going to "pop" out with a little bit of pressure doing it the correct way.. any suggestions would be great. Its accessable threw the speaker hole and the little vent in the door jamb.
Tom
Pics
Tom
Pics
Car: 1991 Camaro RS
any suggestions for the dent? and would i be able to get a used one and put my own glue or double sided tape on? to attach it once the dent is removed? or do i have to go new with a gm part
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It's hard to tell about the dent, try popping it out from the back, it just may pop out. It looks like you can reuse the molding but if you can't, grab one from the JY.
Car: 87 Camaro IROC
you can probably access that from behind the speaker. take off the interior molding where the speaker is and where the seatbelt comes out of. that should give you access to that area.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
well, you'll have to find it used because I hear that GM does not make it anymore....like a LOT of the parts for these cars....
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
go to an autobody shop or store for the proper tape or sticky substance to re-stick the door molding
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Street Lethal
Aug 12, 2015 11:33 AM
