Headlight question...?
I just bought a 91 Firebird that had a light front end hit.
The previous owner replaced one of the headlight assemblies, and included a second assembly that was uninstalled.
Here's where things got strange...
The passenger side headlight (the one he replaced) is larger than the untouched side.
The used headlight assembly he gave me also has a larger headlight in it. I was happy since it matched better the headlight he put in.
I installed the headlight assembly, no problem... Went to plug the headlight in, and the plugs on the headlight were wrong. (see crude drawing below)
The stock wire harness has a connector that looks like this: \ _ |
The passenger headlight has the correct plug, but the drivers side one I installed has a connector like this: | _ |
uh... Can someone please tell me what year headlight I need to buy to get a large bulb with the correct plug for 91's?
Hope that made sense, I'm under the influence of large quantities of Nyquil
... Goodnight... Thanks!
--ElmoTheDestroyer
--ElmoTheDestroyer
