hoods NEED HELP
Old Jan 29, 2007 | 02:49 AM
TransamSBC's Avatar
Car: 1991 TransAm
Engine: 1969 360 sbc
Transmission: th350
Axle/Gears: posi 4.11 gear
hoods NEED HELP
I am taking out the lights in my trans am firbird i have a question can the hood from a camaro fit it i need to know because i can geat a 4" cowl for cheap but it is for a camaro thanks
Old Jan 29, 2007 | 03:13 AM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
you won't be able to use just the hood, camaro hoods are totally different shape/slope so you'll have to use the entire front clip: fenders, nose, hood, headlight buckets ETC.
it's not a easy project but has been done, do a for transmaro and you'll find some information and pics, that will help you decide if swapping out your entire front end is worth it to you.
good luck with whatever you choose
Old Jan 29, 2007 | 10:03 AM
90_T/AGTA's Avatar
Car: '90 GTA
I would just get the cowl hood that has the cut outs for the t/a's lights it will save you a ton of work in the long run.
Old Jan 29, 2007 | 10:17 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
There were kits made to convert the Firebird from pop up to fixed headlights.But I'm not sure who made them or if they are still available(possibly you could modify a Corvette kit).That's if you just want to do away with the hidden headlights.As 88KARRV6 pointed out it's not just a simple matter of changing the hood you'll have to swap out the entire front clip to a Camaro clip(including all the support hardware behind the nose).
Old Jan 29, 2007 | 01:55 PM
TransamSBC's Avatar
Car: 1991 TransAm
Transmission: th350
Thanks I am goin to look for the transmaro and see if i want to do the swap..
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
