Rust
Old Mar 5, 2007 | 08:19 AM
eruk's Avatar
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
Rust
So today i went out to swap in a new rear end and i noticed that on the insider lip of the rear 1/4 panel there is a huge rust bubble. I was wondering what would be the best way to fix it.
Old Mar 5, 2007 | 09:38 AM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
if its just bubble rust sand it down good and spray some rust fix stuff down or use ruberizer.
Old Mar 6, 2007 | 08:19 AM
eruk's Avatar
It is between the layers of medal on the lip
Old Mar 6, 2007 | 04:52 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
grind the rust out and off, and use fiberglass repair, lots of sanding work and primer and paint
sealing it from the air is the goal here, to prevent the same thing from happening again
i wish mine just had a rust bubble only,
https://www.thirdgen.org/forums/body...ff-rusted.html
good luck
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
