door problems
Old Mar 14, 2007 | 09:22 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
door problems
so the outside door handel on my car has been loose, and i broke teh inside door handel so i have to roll teh window down to get out and pull the outside handel, is there an easy way to fix this cheap? i striped the screws to get the pannel (locks and mirros) on the door to get it off (Dam GM and the star screws) should i take it to a shop? how much will it cost? replace the whole door? how much would the "popers" be if i shave the door handels when i repaint the car? is there some easy fix i dont know about?
Old Mar 14, 2007 | 10:33 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
CHILL OUT HAUS, go to your locar JY and take the parts fron a donor car for maybe $.5 It is all in the repair manual and is an easy fix if you are inclined? All it is is a small broken clip replace it and you are good to go. PS if you own a third gen please purchase a set of TORX BITS and you won't have to swear to GM anymore.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
