Door pins and bushings
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Sorry if this has been posted before, but what would be the best way to go about changing my door hinges? Should I pull off the whole door, and change both hinges, or get new pins and bushings? Because my drivers door drags against my rocker moulding when I close/open it, and it drives me nuts..
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
save some mony and just order the pin and bushing kit from Top_down solutions. I just did this to my car and it worked like a charm.
Re: Door pins and bushings
How long were they rubbing??If the bushings were worn for a while you may have to weld the bushing holes shut and redrill them<otherwise the bushing will fit to loosely.Change the top bushing also it wont last very long with the new lower.
Hotrodboba400
Dec 10, 2019 07:07 PM
MikkoV
Sep 9, 2015 04:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
